B16, B18, B20
By egcivicboy
#269651 I'd just like to know peoples thoughts on these two. From what I can see they're pretty much the same. One of them will be going into my 95 hatch over the next couple months. :woot:
As of now i'm leaning towards the JDM b18c because I've found a complete swap kit and friends have been telling me they would recommend that.
anyways. thoughts? recommendations? thanks.
By RWMIII
#269683 JDM has 11:1 CR and USDM has 10.6:1 CR. That is the only difference.
By egcivicboy
#269707 Oh yeh. I saw that. but does that make much performance difference?
By RWMIII
#269709 approx 10hp. the USDM powerband stops at 7800 RPMS, the JDM goes all the way to 8100 RPM. Torque curves are exactly the same.
By RWMIII
#269712 IMO I would just look at whichever is cheaper for you to get. Not enough of a REAL difference to say that one is better than the other.
By egcivicboy
#269714 so JDM is better?
also would you know of a place i could find a complete swap for the b18c5 online? to compare prices?
By RWMIII
#269715
RWMIII wrote:IMO I would just look at whichever is cheaper for you to get. Not enough of a REAL difference to say that one is better than the other.
By egcivicboy
#269718 I've looked through those sites and all i can find is the b18c. I cant find the USDM version.. maybe i'm just retarded Idk.
but this is what i was looking at thoughts?
http://www.bestofjdm.com/COMPLETE-PACKA ... honda7.htm
By RWMIII
#269720
egcivicboy wrote:I've looked through those sites and all i can find is the b18c. I cant find the USDM version.. maybe i'm just retarded Idk.
Never heard of that company. Here is the Type R from hmotorsonline.com :
http://www.hmotorsonline.com/shop/sc200 ... item=30010
sunrise:
http://www.sunrisejdmmotors.com/engine_ ... age=1&F=ME
jspec:
http://www.jspecauto.com/catalog_produc ... rod_id=739
jdmsource:
http://www.jdmsource.ca/products.php?JD ... fbm5flut50
Jdm type-r will only be stamped B18C, you will have to look at the intake manifold, valve cover, or if the company says its a ITR, Spec R, Type R, etc...
By RWMIII
#269723 yes, that is a complete swap.
#269756 The 98+ JDM ITR motor has one of the best trannys. B16a 1st- 3rd with the GSR 4th and 5th and a 4.7 final drive all together with a LSD stock. No other ITR got that tranny that I know of. I know the USDM ones didnt get it.
