- Wed Aug 03, 2011 1:08 pm
#266022
Hey guys hows it going . I Got this built b20vtec setup in my 94 civic eg dx model thats a pain in my ass . The motor gets fuel but does not get SPARK ! Ive been searching but cant find anything more than just dizzy promblems and stuff . I went through everything that would cause my car not to get spark like , got a BRANDNEW distributer , rota , wries , plugs , grounds are there , thermestat ground is good , main relay works , fuel pump primes , i believe that the motor has compression , timing is right , firing order is right . The motor is throwing CEL , so I plugged in my S manager and got 3 codes .
code 10 . IAT-Intake air temperature
code 20 . ELD-Eloectrical load detector
code 21 . VTEC-Vtec spool
Im sure none of the codes im throwing would cause the car not to get spark . The Yellow/Black wire to the distributer gets power and also the coil in the distributer gets power . Now whywouldnt my car start ?
