- Sun May 29, 2011 11:01 pm
#257322
ok so my b16 has a blown head gasket . Its about the same price to fix it and to finish my poorman so im finishing it. my question is should i just go with gsr internals with itr pistons or b16 pistons. Or the stroker combo the ls crank, rods with itr pistons. I would like it boost it in the future so i want the best setup possible. Also I would like to make it reliable so i think the stroker combo is the not best combo.
gsr internal with itr pistons
gsr internal with b16 pistons
ls crank and ls rods with itr pistons
ls crank and rods with ??? pistons
if yah have any other options please tell im all ears and i want the best setup for power also reliable to.
if this helps i have b16 head with itr internals with b17 cams
gsr water pump, oil pump, timing belt
also everything is oem
