- Mon May 02, 2011 3:23 am
#253250
To answer your question tapping of the block is done with an 1/8th inch pipe tap its a special pipe thread, personally I'd recommend a sandwich plate,
the 22t water pump and gsr belt is needed , also I'd recommend arp head studs
rod bolts are also good, but for the rod bolts you'd have to resize and balance the rods
For the oil pump your a1 will work fine , its a simple thing to make the pump a "vtec" pump..... simply pull the oil pan off, pull the oil pump pickup tube off, this will expose a large Allen head should be gold in color and it.holds the oil pump spring in, carefully loosen this Allen head (be careful not to round it some of them can be kinda tight) on the Allen plug there is a small flat washer that almost looks like it would be a gasket ( its actually a spacer) for the plug to seal, discard this and re-assemble (a very small dab of gasket sealent will not hurt to put on the threads of the plug), that's he only difference between all the pumps the late model pumps 96+ spec do not have this small spacer there nor do any previous years vtec pumps....
Hope this helps
PANDA CREW No.20
