- Tue Apr 26, 2011 9:51 pm
#252484
EG6b20R wrote:beerys95lx wrote:That what I was thinking to and I could alway buy a spoon engine later if I ever get bored with it. Does anyone have a b16b swap if you do how do you like it? And how hard are they to do?
They are the same swap as any other B series into an EG if that's where it's going. all that needed is OBD2-OBD1 conversion harnesses and if your car is not wired for vtec get it wired for vtec. Also The ECVU must be prepare either with a virgen p28 or a chipped p28 with a B16B base map to run the motor..
Also this is not your typical B16 motor. It has a more Aggressive OEM camshaft alont with other goodies so it's fun!
If i were going to do a b16b into an eg, I would buy the swap like your planning , then get a sohc vtec engine harness so its obd 1 lengethn any plugs you may need to use the injector clips from your obd2 harness (splice and solder them in) and also the alternator plug but there color coded, and get a update harness to use the obd2 distributor and send an ecu to phearable.net and have john do a b16b base map for you. That's a simple step by step.
Oh and if you order a complete swap you will need to get Linkage for an eg or integra, as the b16b was and ek chassis only and the linkage is different
PANDA CREW No.20
