B16, B18, B20
By beerys95lx
#248174 ok anwsomeness so what kind of fuel system up grades are needed to run this sit up. in ether the ls or the b20 making around 450whp on 16 to 20 pounds of boost
BOOST THE BEAST!!!!!
By beerys95lx
#248195 ok i was lookin at a Turbonetics t3/t4e is it a good turbo for the power i want to make and is it a small or medium sized turbo?
By forcefedEG
#248410 Have a walbro pump, precision 440's, a b&m pressure regulator, and a fuel pressure gauge, that's all I could really see as things I had to upgrade in the fuel system.
And there are so many variations on turbonetics turbo, there are many different trim sizes and there are actually many different formulas for mapping out what compressor side you need and determining the right trim size, there really is no one size fits all turbo... also for what its worth in choosing a turbo you want cfm over psi, basically the less boost you can run but still flow.the same amount of air the better off you are.....
For what its worth I have a t3t4 and its a .60 trim.... I like it for the street, my ls spooled it fairly quick, it lags some on the b16 some though....
By beerys95lx
#248483 that what i was thinking about getting that turbo so good
By Fada Blayne
#249141
EG6b20R wrote:The thing Now adays is People using slighty higher then normal Compression rations and going turbo. instead of the usual 9.0:1 they will go 10.0:1.. Why i dont know it's new to me.
The reason for this is so that there will be less boost lag and also more power being made n/a before the turbo spools.
By Eg6H2D
#249168
^^^ Hahahahah!!!
By 94EJ2
#249186 i think my buddy has a b20vtec for sale if your intersted i dont know if he still has it or what he wants for it i can ask him if you are interested
By beerys95lx
#249258 i am man ask him see what he wants for it
By 94EJ2
#249417 apparently he has to get it put the rest of the way together and running before he decides if he wants to sell it so i will let you know when i know
By beerys95lx
#249449 ok man and do you know what head his run on it and anything else u know abut it
