- Fri Mar 25, 2011 1:18 pm
#246158
well here the idea for my setup:
wiseco -18cc pistons
eagle h beams rods
type r oil pump
gates racing kevlar time belt
arp head stubs
super tech block guard
acl racing bearings
cometic head gasket
i also like to use a gsr head but don't know what cams i'll need if any.
i like to make about 350hp at the wheels. on around 10psi to 16psi of boost
i need it to kinda reliable because i'd to DD if. i'm should i'm missing something in here. so you like to sugest something i use use to build boost or just tell what your running because i'm new to boost and B seires engine so i know there be a learning curve to this
post anything that met help me with this please your help will be a big help to a newbie thanks
