Temperature spike?
PostPosted: Sun Nov 07, 2010 11:21 pm
by Cl9junky
So yesterday i was driving home and just as i was getting home i noticed that the temperature was above average but i was so close to home it didnt matter. I get home check everything no coolant in the oil everything checked out good. Today on the way to work about a 20-25 minute drive same thing happen as i get close to work i seen it creeping up again but i countinued to drive and then it started to drop back down to normal temp. and stayed there. Any idea on why this would happen? Maybe the thermostat is sticking?
PostPosted: Sun Nov 07, 2010 11:36 pm
by si-b16
Sounds like the fan ain't turning on...
Go out for a 20 min drive, pull over leave it idling an check if the fan turns on, if it doesn't then that is your problem, You can also check the fan motor by bridging the two pin fan switch with the ignition 'ON' If it doesn't turn on that means your motor or switch is broken, if it does turn on then I'd say it be a problem in the wires.
Why it started to drop back, is that since you were moving your getting the air into your radiator an it starts too cool it down, that's why you will notice it starts to overheat in city driving, and it stays fine when your up at speeds.
Check out my thread i made - http://civic-eg.com/viewtopic.php?t=17531&highlight=
PostPosted: Sun Nov 07, 2010 11:51 pm
by Cl9junky
Good info si-b16 i will try that asap. Thanks
PostPosted: Sun Nov 07, 2010 11:55 pm
by si-b16
All good, Let me know how it goes :wink:
PostPosted: Mon Nov 08, 2010 1:02 am
by flyinryan122
^^ That and check the temp sensor on the side of the cylinder head, under the distributor. it's the small one wire sensor. There is only one. You can take it out (CAUTION: Coolant will leak out.) plug it back into the harness, and lay it so it can ground out. If you turn the key to the ON position, and get it to spark, it's good. If not, it's a bad sensor. That sensor is what controls the needle in the cluster.
PostPosted: Mon Nov 08, 2010 1:19 am
by {ikon}EM1
^^^^ exactally what I was gonna say...
PostPosted: Tue Nov 09, 2010 12:24 am
by Cl9junky
Thanks si-b16 I just went for a little drive to test out what you suggested and you were right the fan is shot. No biggie though gives me a reason to buy and super duper JDM/OEM/USDM/EDM slim fan!!! :lol: :D
PostPosted: Tue Nov 09, 2010 2:22 am
by {ikon}EM1
don't rule out what flyinryan122 said it could be that too
PostPosted: Tue Nov 09, 2010 3:31 am
by si-b16
Haha good luck with that mate :thumb:
But until then do not get stuck in a traffic jam, it will do lots of damage to ya engine...
PostPosted: Tue Nov 09, 2010 5:27 am
by Cl9junky
{ikon}EM1 wrote:don't rule out what flyinryan122 said it could be that too
I dont think is the temp sensor cause it seem to run hot right before i get to work or right about 20-25 mins of driving and the fan wont power up.
PostPosted: Tue Nov 09, 2010 5:29 am
by Cl9junky
si-b16 wrote:Haha good luck with that mate :thumb:
If thats the case i will shut it off and push it the rest of the way lol. :thumb: and mean dam its light enough for me too :lol:
PostPosted: Tue Nov 09, 2010 11:27 pm
by Eg6H2D
flyinryan122 wrote:^^ That and check the temp sensor on the side of the cylinder head, under the distributor. it's the small one wire sensor. There is only one. You can take it out (CAUTION: Coolant will leak out.) plug it back into the harness, and lay it so it can ground out. If you turn the key to the ON position, and get it to spark, it's good. If not, it's a bad sensor. That sensor is what controls the needle in the cluster.
x2 :thumb:
