F20, F22, F23
By thenewvessel
#331690 I don't hear the fuel pump noise as usual and after a few attempts I squeezed the fuel filter hose leading to the pulsation damper and I don't feel any gasoline or anything. I feels like the hose is empty.
Is the fuel pump bad??
I tried to check the fuse for it but can't find it.
Anyone have the fuse diagram underneath the steering wheel?
By Fada Blayne
#332280 wat ecu/basemap are u trying to start it with?
By bigJOE671
#332283
thenewvessel wrote:I don't hear the fuel pump noise as usual and after a few attempts I squeezed the fuel filter hose leading to the pulsation damper and I don't feel any gasoline or anything. I feels like the hose is empty.
No Start diagnosis 101 --------> http://civic-eg.com/viewtopic.php?t=24927
Fuse box diagram interior
Swap out your main relay with a known good one to see if that fixes it. Usually those go bad after a while. I had to replace mine.
