F20, F22, F23
By BoostedEg8116
#280261 I used one the rad out of a prelude an those hoses
By F2DEG
#287454 I used the original F22 Hose, But I had to cut it just a little bit.
By TrailerTrash
#287456 chances are, if you dont have to make your own, youll have to at least modify some to fit.
By F2DEG
#287457
TrailerTrash wrote:chances are, if you dont have to make your own, youll have to at least modify some to fit.
That is correct. I used the stock hose, But it was a bit long and was kinking the hose, Therefore I cut about 3 inches off of it, and it fit perfectly.
