- Wed Nov 17, 2010 4:40 am
#223258
Ok, picking up a accord with a f22b1 5speed in it. mild build already done to it, but everything is there. it was t boned so getting it for cheap. Now, I know I need mounts and axles, but what I am not sure about is wiring and adding sensors for this engine. I hear millions of different opinions and I am not quite sure what to do. my cx is already converted to vtec and 4 wire o2. planning on chipping a p28 and using it. just curious about wiring. will have the f22 harness just want to know what needs to be done. thanks guys in advance. hopefully you will have 1 more f-swapped eg on the roads by january
- Fri Dec 10, 2010 6:04 am
#227081
use the eg harness and a chipped p28 or the ecu that was used with the motor before if it came out a 94 or 95
- Fri Dec 10, 2010 6:06 am
#227083
Poa?
- Fri Dec 10, 2010 7:24 am
#227104
Figured til i turbo it i will use the poa then switch to a chipped p28
- Fri Dec 10, 2010 7:41 am
#227108
Mooze have you used the f2b? If so pm me.
