- Mon Jan 10, 2011 8:35 pm
#232528
Hmm The RBC intake manifold work on a h22/23 head now using a QSD adapter. But as tested. the Euro R manifold is slightly better utilizing more TQ in the lower end of the RPM..
chrono404 wrote:K20 Heads and Intake Manifolds will NOT Work on an H/F Block.
For one K Series uses Timing Chains, H/F's use Timing Belts.
for a "G23" you need a F series bottom end, K Series pistons and H series head. Just like for a "poor mans type-r" you need a B18c(GSR) Bottom end and a b16 head. If you use a GSR head its not a poor mans type-r, if you use a ls/b20 bottom its not a poor mans type-r.
If you build a F23 block up and use non-k pistons, then slap on an H22 head you have a F23 Hybrid. Not a "G23"
They have been around a lot longer then the so Called "G22" and "g23" Names.
Team XXX Racing/WGHonda
