J30, J32, J35 & J37
By Carfanatic
#157127 i hate J swaps.... :x
Carfanatic wrote:i hate J swaps.... :x
They are good for Drag Runs, but kill your handling. I can you can compensate with bigger swaybars but even then.
J Series is good for Street Drag. And kinda the new path to go down.
I like my handling to much to go for one now.
I will go for my LS/Vtec for now. And wait for hondas A-VTEC engines to roll out of the factory before swapping to a new series.
By BLaCkSiLo
#160319
what is this A-VTEC? and i would dig an LS/VTEC swap :thumb:
with the J series, you can't handle and you can't see over your hood... it would be a monster tho!
By JUICE
#160324 Advanced Vtec
It combines continuously variable valve lift and timing control with continuously variable phase control.
By 3kkl3sia
#160327
Honda has announced it’s next generation VTEC engine, the Advanced VTEC engine (AVTEC) which will make it’s debut in a production car within the next three years. Honda’s new Advanced VTEC (AVTEC) engine combines continuously variable valve lift and timing control with the continuously variable phase control of valve timing to achieve a good combination of better performance, fuel economy, and lower emissions. This is an improvement over the i-VTEC system which has preset changeover settings in valve lift – the new AVTEC system can adjust the valve lift continuously. There is also a variable-length intake manifold to improve intake airflow.
The Advanced VTEC (AVTEC) system allows optimum control over intake valve lift and phase in response to driving conditions for a significant increase in torque across the engine rev range. Under low and medium loads, the valves are set to have low lift and early closure – this reduces pumping losses and subsequently improves fuel economy.
The new AVTEC system will allow for a 13% improvement in fuel economy over the current i-VTEC range of engines. The 13% figure was obtained comparing the current K24A 2.4 liter i-VTEC engine with a new 2.4 liter AVTEC equivalent. Emissions are compliant with US LEV2-ULEV standards and Japanese Low-Emission Vehicles standards with levels 75% lower than 2005 standards.
http://paultan.org/2006/09/26/honda-ann ... ine-avtec/
By knuckles-ej1
#205143 "with the J series, you can't handle and you can't see over your hood..would be a monster tho!"
actually j swaps braking weight transfer is about 63/47 compared to 60/40 for MOST fwd and hasport makes a mount that allows the j swap to fit in the bay with no hood fab.
By asianrob
#205144 http://www.youtube.com/watch?v=p64BZVk3Fus
so far this is the only v6 civic i seen that has a stock hood that hasnt been cut and this one has been out for ages...
By jayEGR
#205147 thats shit sounds sick as fuk :thumb:
By EG_Ryder
#209840 Hasport makes mount now where you can either have it comming out of the hood or you can flip the mounts over and your hood will be flush, but the motor will hang down a bit(which shouldnt be a problem with stock height)
By jswappedsedan
#250112 if anyone has any ?'s about the j swap let me know or u can check out j32a.com
By dbrooks
#250163 ^^ have you made a build thread yet?
By jswappedsedan
#250182 Kind of....don't like to put all my business in the streets because were I live there's alot of thieves but u can check what I did post on j32a.com... I have some pics of build I can post on this site....will do when I get home
