J30, J32, J35 & J37
By 92dxeg
#325130 is there a deffrence between the two swap wise or is it like a b16 and a b18. does the 35 sit higher then the 32
By bigpunn421
#326327 i would suggest talking to my friend don at rpm systems. he is the j series guru. he is in ny. or sign up to j32a.org
i know the j35 is taller than the j32.
j35 block with j32 heads is a nice setup.
6 speed lsd trans is hard to source too. honda only made 3500 cl type s in 2003. the only year
they make j37s now too in newer hondas.
you can do a j32 swap without cutting your hood too. don makes custom mounts that lower the motor. for more of a sleeper
if you want a 6 speed get a manual motor. if you get a auto motor with 6 speed you have to change a bunch of timgs. but if you find a cheap crv j35 get it
also the cl and tl trans missions bolt up different
i know people who make over 350whp on a factory build. and they get over 40mpg
