- Fri Feb 05, 2016 7:35 pm
#358376
ok this might be kinda long guys.
a few years ago i had a thread about this exact issue and i solved it. this time its not so easy.
the problem just started randomly on my way to work. the car sputters under load. like unless you ease onto the gas very slowly it will sputter and buck and carry on. if u rev it up it does the same. if u give it gas too quickly it will either stall or stall and puff smoke out the intake. then it is hard to start. it is hard to start hot period when this is happening
when i had this exact issue before i tried
main relay
fuel filter
injectors
distributor
cap/rotor
plugs/wires
coil
none of that helped. this is all with NO CHECK ENGINE LIGHT. then randomly the CEL flashed while running and i checked the code and it was the coolant tempature sensor. so i bought one and it solved the problem for 4 years or so.
untill last month. exact same symptoms. the sputtering ect its almost undrivable. checked the codes and there werent any. played around with it for awhile and again the CEL came on i check the code and bingo the CTS
so i got a CTP and it did the trick. i let it warm up several times then started it hot and had no trouble. then i drove it 10 miles and it started all over again. so i thought just my luck i got a defective sensor. so i tried a spare i have on my spare engine. didnt work. so i bought another new one(different brand) and it didnt make a difference.
it idles fine.
coolant system is bled
no CEL
and just to be 100% clear, i did buy the coolant tempature sensor for the ECU. not the one for the gauge. and i tried 2 used and 2 brand new
and i disconnected the battery each time to clear the code
please help guys im ready send this thing to the dump!
main relay
fuel filter
injectors
distributor
cap/rotor
plugs/wires
coil
it idles fine.
no CEL
