- Sat Oct 03, 2015 2:26 am
#356297
So, I know that I need a Y8 cam gear and I need to re-adjust the ignition timing when I install it.
other than that, the process should go like this?
1) Set B7 crank and cam to TDC
2) Replace B7 Cam with A6 cam+ Y8 Gear
3) bolt everything back together
4) Adjust Ignition timing by rotating dizzy
Is that all? Does the cam gear only go on one way? I'm afraid of messing up my timing.
Someone help me out here
