- Tue Nov 04, 2014 6:39 pm
#349613
95Ej2civic wrote:I'm not wanting to go boost or have a b series. I'm wanting to build a solid d series because there isn't many around my area. Hp is not my biggest concern to have a lot of. My goal is to have a solid d series that's strong and reliable. I've seen it done so I know it's possible. I'm not looking for crazy hp or anything like that. I know what I want and it's a solid d series motor that's reliable not fast or anything. Just wanting a solid motor that's all. I always see b series and k series I want somethin that you don't see all that much and I will make this build happen. I was looking for help not trying to be steered in another direction of a build that I don't want to do.
not steering you any way, just stating known facts. based off the comments you've been posting, you have no clue what you are getting in to nor have you read any on the subject of building one of the engines to begin with.
if you want a "solid, reliable" engine just leave a D series bone stock...there ya go, solid and reliable. asking what parts to buy is completely irrelevant because only you know your true goals and only you know how much money you have to blow rebuilding a 20+ year old engine. you may have tons of money to blow but to most folks these days, its kind of hard to justify spending 2-3k building a 150hp d series but anyway.. there is a build thread on DSO of a guy that makes a d16/d17 stroker that puts out some good torque numbers but as you've stated, you aren't building for power. it sounds as if you are looking at more of a rebuild with fresh components from what I'm gathering.
just start by doing a rebuild on the head, pull it all apart and take it to the machine shop to get the valve guides replaced because they are likely toast, then buy some cheap crower springs, use your stock retainers, buy a quality cam or get a regrind from delta or web, buy some cheap rods(spending lots of money on rods is a waste so buy the cheaper ones) buy whatever pistons you want to use to get you to the compression you want to hit, buy all your "rebuild" components. check all the tolerances, assemble and install then get a tune.
My EJ1
http://civic-eg.com/viewtopic.php?t=240611989 accord lx-I - sold
94 civic ex sedan - sold
93 cx hatch gsr swap - sold
94 civic coupe gsr swap - sold
94 cx hatch d15b turbo - sold
94 civic coupe d16y turbo - current build
