Low Idle!
Tue Aug 12, 2014 3:35 am
by 95_relio
My 95 civic has a low idle problem where my needle is right at 0. Anyone out there had this problem and fix it?
[/u]
Tue Aug 12, 2014 8:37 pm
by baconsauce
as it runs on 0, are you sure that your tachometer actually working?
Tue Aug 12, 2014 8:39 pm
by baconsauce
and if it is working you can just adjust the slash bolt on throttle body so idles should goes up or down depends on how you screw it.
Tue Aug 12, 2014 10:37 pm
by 95_relio
[quote="Deffyjeffy"]and if it is working you can just adjust the slash bolt on throttle body so idles should goes up or down depends on how you screw it.[/quote]
Yeah my tach works I'm sure of that I'm just saying that it idles so low that it's down to that little line right before the 0 mark on the tach.
Wed Aug 13, 2014 3:38 am
by baconsauce
95_relio wrote:Deffyjeffy wrote:and if it is working you can just adjust the slash bolt on throttle body so idles should goes up or down depends on how you screw it.
hmm. it happened to my car when it went to 0 while my car running fine. I gave it light smack on my dash and it went back to normal (800). I just thinks it is my cluster. let's see if someone else would chime in and helps you out, hopefully.
Sat Aug 30, 2014 10:45 pm
by williamc1991
Im having the exact same issue. I replaced my idle air control valve due to it leaking coolant. Now everything in finding is leading to what's called the fast idle air valve. The car will run fine but it idle extremely low. Mine idles at about 150rpms.
Tue Sep 02, 2014 5:59 pm
by suspendedHatch
The OEM tach isn't at all accurate. Mine will often be at zero but when I connect a diagnostic tach it will be at 650.
If you adjust the screw on the throttle body, make sure you follow the correct procedure or else you'll throw everything off.
Ignition timing has a big effect on idle so make sure it's correct when the idle is within spec.
