By enanoeg92
#344977 I have a 92 civic the wiring is from a si but I have a regular hatch I wanna know why my rpm aren't working and my signal lights break light aren't working I've post this problem before but couldn't fix it could it be cuz I'm using an si harness??
#344984 The Si harness shouldn't have anything to do with it. I'm going to guess something did not get properly connected when it was installed or something got damaged.
Do you mean the engine harness or the cabin harness?
By enanoeg92
#344985 Engine harness I have a regular harness in the cabin
By 93EGVXHATCH
#345315 check your hazard relay under your dash that should fix the indicator problem
