- Wed Apr 23, 2014 8:07 pm
#344956
Hi, I've got an Haynes manual 1991 to 1996.
Top compression ring
All others..... 0.030 to 0.060mm
Service limit ....0.13mm
Second
All others......0.030 to 0.055mm
Service......0.13mm
Ring end gap
Top.....0.15 to 0.30mm
Service....0.60mm
Second....0.30mm to 0.45mm
Service....0.70mm
Oil control D15B7.......0.20 to 0.80
Service.......0.90mm
You have 2 choices
1. You gonna go to Honda dealer and buy the rings set
2. You gonna try the NPR set and see what is going to happen
2.1 Swap
P.s. Maybe the 1.2mm is the ring gap without sliding on the cylinder walls.
cIvic eg4 ImpoRt D15b dUal carbs!
D16z6 conversion going on.
