By DailyDriven94dx
#340995 UPDATE:
I'm pretty sure I found the problem.....blown head gasket. The head gasket blew between cylinders 2-3 but not enough to let water in just enough to share cylinders. I guess the compression test wasn't effected because the cylinders are opposite in the firing sequence. See the link for picture. Also, should I some how clean the gunk out of the coolent channels? Thanks for all your help and I hope this helps others that may have this rare occurrence. I'll update again tomorrow or in the next couple days after I install the head gasket.
https://www.dropbox.com/s/shx5m2zs1401m8j/2014-01-05%2001.22.09.jpg
By DailyDriven94dx
#341015 Fixed and better than before.....thanks for all your help everyone.
By pkaewthong34
#341021 Ooh uh finally found someone that has problem about misfiring and stuff .. I'm suspect my first cylinder right now .. It was only one that happen when it cold .. Once it start up then works fine all day long
