- Sun Jun 30, 2013 8:20 pm
#333667
Hey guys, so today I put a stainless exhaust mani on my d13 single carb, I already had a decat pipe and stainless cat-back, but now I've lost all back pressure and the car is slow as hell :/ my problem is I can't turn the fuel screw on the carb as the engine management puts the fueling back to standard... Has anyone got any ideas if bigger jets would help? If so where would I look and also what size would I get as I don't know what standard ones are..[/quote]
- Sun Jun 30, 2013 9:44 pm
#333668
Changing to a SS exhaust manifold shouldn't require an adjustment to the A/F ratio.
did you disconnect anything you didn't reconnect?
do you have an exhaust leak with is causing the lose of back pressure?
have you tried putting it back to the way it was before and see if it runs proper?
