- Sun Mar 10, 2013 8:03 am
#328225
Hey hopefully someone can help I have eg with 97 civic motor when I first start it in the morning it reves up and down then when it's "warms up" it sputters like if the motor die or sounds like for short little burst all this started happen when I put the ac system back on plz don't know wat else it could be
- Sun Mar 10, 2013 8:25 am
#328226
did you do anything recently? More details will help.
- Sun Mar 10, 2013 8:32 am
#328228
check your coolant level.
* open the radiator to see if you have any coolant.
* any signs of the tubes leaking?
it can be air bubbles in your coolant system causing the rev during start up.. But it can also be other factors. Check the system first as this doesn't cost you anything.
also, you mention, you put a.c. System back on. Did you install the a.c. Or ?
- Mon Mar 11, 2013 3:29 am
#328302
engine cold, remove radiator cap.
Start car, get engine warm. When the thermostat opens and coolant begins to flow, the coolant level in the radiator will drop as the air comes to the top. Just keep topping off the coolant level as it drops and you'll replace all the air pockets with coolant.
enanoeg92 wrote:How do I bleed the coolant system
- Thu Mar 14, 2013 2:16 am
#328551
wait... is your check engine light on? If so, check the code:
http://civic-eg.com/viewtopic.php?t=1558
- Thu Mar 14, 2013 2:06 pm
#328578
Does it turn on when you turn the key to start the car? if not, it's burnt out or removed.
