- Mon Mar 04, 2013 12:24 am
#327650
i just changed out my coolant.
followed the steps in the owners manual
drain
put bleeder bolt + drain plug back in
fill up to filler neck
bleeder bolt (no bubbles came out BTW it was already a steady stream)
then I tightened that back in
started the car up for at least 30min and heres the problem
problem >>>> radiator fan never turned on not even once!
what should i look for ...i suppose fuse or something right?
// my car didn't over heat
// no other signs of over heating
// a little smoke came out the back but thats normal
// its sorta of cold here in SF i think 40-50 degrees idk if that matters
drain
