- Mon Feb 25, 2013 4:54 am
#327228
Alright well this leak has been going on for a long time now and I still don't know where its coming from. All the oil leaks from the top of the tranny to the bottom. I swear the whole tranny is covered with oil. Its like coming from the bottom of the distributor ? Help?
- Mon Feb 25, 2013 5:09 am
#327229
check the dizzy seal, and the vtec sol. gaskets, mine leaked fron the sol and would run all down the trans.
- Mon Feb 25, 2013 5:15 am
#327230
Yeah man its just running down the tranny. U think they sell theses seals
at auto zones ?
92civic_vx wrote:check the dizzy seal, and the vtec sol. gaskets, mine leaked fron the sol and would run all down the trans.
at auto zones ?
- Mon Feb 25, 2013 5:32 am
#327232
[quote="rustyrex"]AutoZone only carries the dizzy o ring. I used to manage one. The seal inside the dizzy for the shaft you can find online. Replace both and your golden.[/quote
So replace the O ring and the seal inside dizzy shaft and I'm good ?:) what about the VTEC Sol? ]
- Mon Feb 25, 2013 1:54 pm
#327247
Clean the engine off and isolate where the leak is coming from. Shouldn't be that hard to see. No need to re-seal everything on that side of the engine for no reason
1992 Honda Civic SIR-S
- Tue Feb 26, 2013 1:17 am
#327299
Check this thread http://www.civic-eg.com/viewtopic.php?t ... highlight=
I gave a pic of the gasket part number from felpro I got at O'Reilly and added it written. Hope that helps and check the vtec solenoid.
It belongs in a museum!
- Wed Feb 27, 2013 12:05 am
#327343
Thanks for the help man
HeikDiesel wrote:Clean the engine off and isolate where the leak is coming from. Shouldn't be that hard to see. No need to re-seal everything on that side of the engine for no reason
#327344
That helped a lot man thanks !
onibakagaijin wrote:Check this thread http://www.civic-eg.com/viewtopic.php?t ... highlight=
- Tue Mar 05, 2013 12:05 am
#327751
damn guys my leak went away for a little bit but now the leak is back again but from the back. maybe solinoid like others said ?
Martin_Bros wrote:onibakagaijin wrote:Check this thread http://www.civic-eg.com/viewtopic.php?t ... highlight=
- Tue Mar 05, 2013 12:07 am
#327753
- Sat Apr 06, 2013 5:27 pm
#330166
[quote="MG6"]is it near the val cover? If so, change both as I just changed my dad's one.[/quote.
Damn I just sealed my solenoid and my distributor but still a leak from the back of the engine what you think?.
