- Tue Feb 19, 2013 10:31 am
#326786
Hello everyone,
I'm from the u.k, and currently drive a eg3 with a jdm d15b single vtec,
The swap consists of
P08 ecu
Eg5 main dash loom (eg5 the model that has the d16z6 motor)
Jdm d15b engine/box with original engine loom,
After I installed the swap I got NO cel codes, so as I'm about todo the
Ignition timing using a strobe light gun, I bridge the cel check plug
And I get a code 20, ELECTRONIC LOAD DETECTOR.
The cel light only turns on when I bridge the cel check plug?
After reading/searching around various forums, I believed the eld is located in the main under hood fuse box so I got hold of a different fuse box and installed it but still got the code 20?..
Is there any other way I can set the ignition timing without having to bridge
The service/cell plug? And am I right in thinking that " in order to set the ignition timing with the strobe light I need a solid lit cell light?."
I'm getting around 28 mpg u.k (4.5 liters in 1 gallon) that's driving like a grandad. Car is idling at 850/900 rpm when fully warm,
1 more thing when I unplug the lambda/ oxygen sensor I get no cel light?
Is that normal with the p08? And voltage check at the lambda is 0.47ish or could it be a faulty lambda/oxy sensor?
Also I've got no charcoal canister? Could that cause bad mpg and unbernt veil smell from the exhaust or fuel tank itself?
Sorry for all the questions, just really baffled as I just want the motor to run beutifuly. Thank you.
P08 ecu
