By enzoferrari
#323570 Hi
I have a JDM 1992 Civic Si 4-door with D16A9 engine. The injectors are bad and I can't find new or used OEM injector here.
Which injectors can used instead of OEM injectors?
What is the part number of the OEM injectors?
#323586 They are 240cc. However, you will need to check if your car has the resistor box. A resistor box is used for Peak & Hold Injectors (aka low impedence injectors).
The OBD1 D16z6, D15b7 uses a 240cc injector but it is the "Saturated" type of injector which does not use a resistor box.
THere's a picture of a resistor box in the picture.
Saturated and Peak & Hold injectors cannot be interchanged unless removing/adding the resistor box. (or ecu/injector damage could occur)
By enzoferrari
#323932 Thanks
Which brand and part# I can use instead of the OEM injectors?
#324014 You could go aftermarket with a set of RC injectors, they make a 240cc injector. You may have to search online to find a store /seller who will ship world wide.
Our vendor Corsport ships world wide and they also sell RC Injectors.
http://www.corsportusa.com/store/catalo ... tional.php
