- Sat Jan 05, 2013 9:14 pm
#323372
I have 92 hatch with d16zc with vtec head. Problem I'm having is my distributor went bad so I bought a used one and installed it and cel code 9 popped up, i reset the ecu and still there afterwards. So I went back they gave me another dizzy but this time cel code 8 popped. Went back again got another dizzy and again code 8. Just lost right now...[/i]
- Tue Jan 08, 2013 5:20 am
#323501
d16z6? And are you getting the correct dizzy?
- Sat Jan 19, 2013 11:43 pm
#324458
yea its the TD42u...figured it out. the harness has a broken wire
- Sat Jan 19, 2013 11:50 pm
#324460
Awesome
mexicanIV87 wrote:yea its the TD42u...figured it out. the harness has a broken wire
Awesome
- Sat Jan 19, 2013 11:59 pm
#324461
hey i do have an other question though...the broken wire that i need to repair is wrapped around actual wire and plastic casing...can i cut it off?
- Sun Jan 20, 2013 12:39 am
#324464
Im not sure i understand, wires have insulation. If there is a loom over if as well, cut the tape back so you can repair the wire
