By GotHatch?
#318701 Has it always done this or did it recently start?
By gtstripes
#318719 check the pedal... might be abit stuck...
i fell for this after i sold my hot pink eg hatch for $200 lol :x awell had money aside anyways :P
By EgCyndicate
#318944 when i bought car it had engine and tranny out of car, d15 engine.. when i finally got spark its been idling high, i replaced ecu cuz the CEL was staying on ..now when i turn the key the CEL light turns off for about a min or so then turns on agian
By brandoff88
#318945 id check what codes its throwing and go from there, see if that helps pin point the problem, hope this helps a little
By EgCyndicate
#318946 WILL DO THANKS
any idea on why the car dies when i unplug the idle control valve?
By brandoff88
#318947 it cant properly meter the idle from there with the sensor out lol, so it just chokes out and dies...and thats pretty much in a nut shell
By brandoff88
#318949 i did the same thing, i had a werid idle and unplugged that and the car died and i was like uh oh....then i plugged it back in and it started right back up :thumb:
