By ChristopherJason
#314642 i changed my Cap and rotor and wires. now i have no spark at all
i put all the old stuck back still no spark.
everything is cranking, theres fuel.
what could it be.
ive read ICM and Coil ? should i buy it ?
By jhicks
#314695 Was it running before hand? did you put the plug wires back in the right place?
is there a bright white spark from the plugs?
By jhicks
#314701
teal_dx wrote:did you see if each plug wire will create a spark by grounding to the valve cover while cranking the car?
:thumb:
By ChristopherJason
#314887 figured out what happened.
engine with 150K on it never had parts replaced
Put on a new Cap/rotor/plugs/plug wires
Killed the coil got a new coil now it runs perfectly
By EG8_CRUSADER^^
#314908
ChristopherJason wrote:figured out what happened.
right on dude, glad everything worked out. :thumb:
By ChristopherJason
#314975 Learned a Good lesson.
Never just replace 3/4 of the shit when u dont kno the car very well. REPLACE IT ALL SINCE ITS CHEAP!!
