- Wed May 23, 2012 3:43 am
#305862
ive got probably a stupid question. ive got the d16z6 in my car. was told the vtec hits at 4500.. is that right? i really dont feel it. could the sensor be bad?
- Wed May 23, 2012 4:35 am
#305869
Stock it should kick at 5300 or 5500 and go until redline. 4500 is low unless it has a chipped ecu. And if you are completely stock no mod's you really won't feel it or hear hit. Put an intake on only and you will hear the change over.
- Wed May 23, 2012 5:24 pm
#305930
its not very pronounced in sohc motors intakes offer the sound alot better than stock airboxes, but your more apt to feel it on a dohc vtec motor and yes it should kick in around 5200 or so
EDIT : meant vtec not ctec lol
94 EX coupe (sold 1/2016)
http://civic-eg.com/viewtopic.php?t=27951
93 DX coupe build 2.0 (R.I.P.)
http://civic-eg.com/viewtopic.php?p=331386#331386
- Fri May 25, 2012 3:31 pm
#306205
Is there a way you could modify the ecu from 5500-5300 rpm vtec kick into lower rpm?
EJ1_MK wrote:Stock it should kick at 5300 or 5500 and go until redline. 4500 is low unless it has a chipped ecu. And if you are completely stock no mod's you really won't feel it or hear hit. Put an intake on only and you will hear the change over.
- Fri May 25, 2012 5:29 pm
#306218
Yes you have to have your ecu chipped. Or find one that's chipped and make sure its a vtec ecu and unless your good with a soldering iron have it done by a professional and reputable shop
Its not about the name of the parts you use its the fact your making the attempt to make it your own
- Fri May 25, 2012 5:40 pm
#306221
ah so if my car has p28 in it, it needed to be matched or replaced?
I don't know much about the computer and ecu system, lol
- Fri May 25, 2012 6:24 pm
#306228
Wire in a vetc light and u will c when it pops of it pops
my shit is runing cuz of this forum
14#COUPE CREW MEMBER
my ricer coupe
http://civic-eg.com/viewtopic.php?p=260106#260106
my ricer coupe
