By xjm92x
#303923 okay i finally got my car to start but it starts idleing at 2000 rpm n stops at like 800 or so , is that bad?
i also have a bad o2 sensor
By brandoff88
#303924 id fix the o2 sensor and then check your idle screw, if you have erattic idle (jumps up and down) could be air in your coolant system..just some things to check :thumb:
By xjm92x
#303926 okay thanks i was just wondering cuz the original issue was the injectors and ive changed them nand now tho low idle has me worried im use to seeing 1500 or so rpms
By xjm92x
#303931 how do i remove the o2 sensor that thing is freakin stuck in
By TrailerTrash
#303936 you could try soaking it with liquid wrench/pb blaster and letting it sit for a few days, resoaking it periodically. that is if the car doesnt have to be driven every day.
or you could let the engine warm up so its nice and hot it might come loose.
i couldnt get mine out when i went from a stock manifold to a header. i ended up having to buy a new one
