- Thu Feb 02, 2012 4:40 am
#292969
I'm going to try to explain this issue the best I can...
say im pulling away from a stop light easy on the gas revving to about 2.5k each shift. from about 1,800-2,500rpms the engine seems to pulsate... its very noticable like someone is gentle easing on the gas pedal yet pumping it slightly at the same time...kinda like
brrrrrrrrrrrrr rub rub rub rub rub rub rub rrrrrrrrrrr
the pulsating is fairly fast and its noticable in the exhaust tone and engine noice and you can feel the car "jumping". if I hold it in that rpm range it will just keep doing it. from idle to 1bout 1800 no problem and from about 2500 to redline no problem.
car runs great no CEL misses or any other issues. I had this problem about a year and a half ago and I just ignored it and when I changed my spark plugs it stopped it all together... then it started happening again in the last month or so and its EVERY TIME i pull out. its mainly noticable in 2nd and 3rd gear in guessing cause of the engine load, car speed, whatever.
so last week I gave the car a tuneup. new fuel filter, cap, rotor, plugs, and plug wires. no change whatsoever. this is very annoying and I know its not supposed to be doing this...
maybe a better explination would be when you are driving very slow in first gear and it kinda chuggs along slightly bucking... thats kinda what its like only faster and not as "bucky" lol doesnt do it just revving it up in neutral or with the clutch pushed in. only when driving
I hope this wasnt too hard to understand... thanks for reading please help
Last edited by TrailerTrash on Sat Mar 10, 2012 11:16 pm, edited 8 times in total.
