- Tue Jan 31, 2012 5:28 pm
#292747
First, if MI has emissions check then don't bother. In OH, an OBD1 motor won't pass emissions in an OBD2 car because OBD2 has some extra sensors that won't have anywhere to plug into on the OBD1 motor, causing a check engine light.
The OBD2 car could use an OBD1 ecu with an OBD2 to OBD1 conversion harness, but then the diagnostic port that they use to scan for codes will not work if an OBD2 car is running an OBD1 ecu.
Putting the OBD2 motor into the OBD1 car is a much easier story. Keep all the original OBD1 wiring, including engine harness. There will be some extra sensors on the OBD2 motor that won't be used. Then you can use a chipped OBD1 ecu and put a basemap on it for the OBD2 motor that you swapped in.
You'll still need to get a conversion harness for the alternator & distributor plugs, although a D15b7 distributor will fit some OBD2 sohc heads, so that is a second option. You could also keep the OBD1 alternator and use that instead of changing out the plug of using a conversion harness.
And you will need to cut your injector clips off the OBD2 harness and solder them , replacing the OBD1 clips, so that the engine harness will plug into the OBD2 injectors. OR if the injectors are the same size on both motors, just keep the OBD1 injectors and put them on your OBD2 motor and that way they will plug right in to the OBD1 harness. I would do that if possible.
Knock sensor, crankcase fluctuation sensor on the motor will both be ignored, as those are only read by OBD2 ecu's.
