- Wed Feb 09, 2011 2:32 am
#237632
Sup Guys and Gals,
I'm pretty pumped up about this build and wanted to document it to the best of my abilities. If it wasn't for the net and all the info left behind by others I wouldn't have been able to do anything like this. So Thankz !
When I got this car (1995 VX) 3 years ago the only toolz I owned were made up of the bare home basics; a Hammer, couple screw drivers, vice grips, pliers, and 4 of those $5-$10 socket sets that everyone gets you for Christmas. I'm not a complete stranger to having to work on a car (poor folk do what that gotta do) but I never thought I'd attempt to rebuild an engine.
The reason for the build is mostly to get the engine(D15Z1) thats in my car now out. I want to rebuild the Z1 later. So why didn't I just do a quick swap with a used motor do ya ask, cause I can't stand the idea of putting someone else's POS motor in my car and just cross my fingers. Another thing is I was fed up and got sick of mechanics saying "Naw, I don't know nuttin bout dem dere Jap motors". So fine, SCREW THAT I say, I'll learn to do it myself!
The Goal is simple:
Build a reliable All Motor D-series with a lil bump in hp. This engine will be for a fun DD only and if it ever sees auto-x then cool. I just want to know I built it and it worked.
EDIT 7/26/2011: ^^^It's a nice story so I'll leave it unchanged (but things do change). A week ago today I bought a 1997 Del Sol S, D16Y7 w/ 138k miles, everything stock with A/C. Needing the extra cash I decided to sell the hatch, it was almost a hard decision. But the engine build goes on and will become apart of the new DD. The build continues....
:::WARNING!!!::: User name Zen Chameleon is building his first ever engine, this said engine is not running yet. Asking user name Zen Chameleon for help could cause any or all, but not limited to:
headaches, frustration, blurred vision, dizziness, confusion, loss of sleep, constipation, diarrhea, projectile vomiting, bloody knuckels, unnecessary work and research, catastrophic engine failure, crying in front of your girlfriend, cronic masterbation, spontaneous combustion, suicidal thoughts, in some but rare cases could even lead you to achieving your goal or solving your issue.
If you have asked Zen Chameleon for technical advice and experienced any or all of these symptoms please seek professional help from somebody that has real world engine building knowledge and wisdom :::WARNING!!!:::
[SIZE="4"] The "Accomplishment" List: [/SIZE]
Head D16Z6:
Work done from Performance Porting:
Mild Port and Polish
3 angle valve job
SuperTech springs, new oem retainers
New oem cam and valve seals
Milled .003 for flatness
Hondata intake gasket
New extended intake studs
Freshly cleaned Z6 injectors
AEM cam gear
AEM fuel rail
B&M fuel pressure regulator
Marshal fuel pressure gauge
AEM CAI
NGK plug wires
D16Y7 block:
D16Z6 Crankshaft
Y/Z6, ARP head studs
ARP rod bolts
PG6 Pistons
P28 ECU socketed w/ Neptune RTP
98' EX Tranny
What's left:
Cam
Bearings
Gaskets&Seals
Oil pump
Water pump
Timing Belt
Machine work on Block= in progress
Wideband O2
Header
and most important Tuning
I think that's everything....if I missed something let me know please
Thankz for all the support
A sneak peek of the '97 Del Sol, New DD/Project:
The Goal is simple:
Head D16Z6:
3 angle valve job
AEM cam gear
AEM fuel rail
AEM CAI
NGK plug wires
D16Y7 block:
D16Z6 Crankshaft
ARP rod bolts
PG6 Pistons
98' EX Tranny
What's left:
Cam
Bearings
Gaskets&Seals
Oil pump
Water pump
Timing Belt
Wideband O2
Header
Last edited by Zen Chameleon on Tue Aug 16, 2011 10:25 pm, edited 17 times in total.
