- Wed Apr 15, 2009 10:00 am
#110744
i have a d15b7 that im gettin ready 2 do a mini-swap to. i heard i can use the stock ecu for the swap just i'd have to hook up a v-tec controller or run it to a switch. and i can use the d15b7 timing belt is this true?
also i heard if i port/box out, i think its the intake manifold. and put a upgraded cam on it it'll make the v-tec hit harder. is any of this true? and what other things will help the vtec hit harder?
- Wed Apr 15, 2009 1:33 pm
#110768
bad idea, get a p28. a vtec controller will not have the proper fuel curves like the p28 would.
porting the IM will not make vtec 'hit harder', but if done correctly can help air flow.
A cam will always help. A sohc vtec will never 'hit as hard' as a dohc.
You might want to test fit with your old d15b7 timing belt, but I believe the timing belt should match the head you are using.
EJcivic732 wrote:i have a d15b7 that im gettin ready 2 do a mini-swap to. i heard i can use the stock ecu for the swap just i'd have to hook up a v-tec controller or run it to a switch. and i can use the d15b7 timing belt is this true?
- Tue Dec 29, 2009 11:25 pm
#164649
i know to use the same distributer(D15B7) with y8 head. and im sure of course you buy the y8 spark plugs. But what about wires and can i use my same valve cover?
- Wed Dec 30, 2009 2:28 am
#164678
the d15b7 valve dover does not fit the y8 head. I used y8 plug wires, if I recall, the d15b7 plug wires didnt fit right.
- Thu Jan 07, 2010 7:35 am
#166508
When doing this swap will i have to purchase a vtec solenoid
- Thu Jan 07, 2010 2:17 pm
#166538
no, usually when you buy a used head it will already have a vtec solenoid on it.
- Fri Jan 08, 2010 7:15 am
#166716
SICK FUKIN write up...im doin this set up like in 2 1/2 weeks..
just need to get my d16z6 timing belt and cam gear (adjustable) water pump and head gasket kit and my NGK wire set and plugs..if i forgot something..please reply or pm me thanks man.. this write up is really helpfull..
reppin ej1squad.com*civic-eg.com
wiredonhonda.com*
WEST LOS ANGELES.CA
Karma's a BITCH, and she plays well!
wiredonhonda.com*
WEST LOS ANGELES.CA
- Mon Jan 11, 2010 4:59 am
#167498
I am on my to doing the mini me swap d15b7 to d16y8! Most of the parts are on te way and i'm ready to go!! Question, Wil my exhaust headers for my d15b7 fit my d16y8 head?? Also porting polishing and milling the new head, what would be possible gains? Whats your take on it thanks.
- Mon Jan 11, 2010 5:29 am
#167505
header will bolt right up. and, the head will flow better, allowing it to make better power
fuhq2man wrote:I am on my to doing the mini me swap d15b7 to d16y8! Most of the parts are on te way and i'm ready to go!! Question, Wil my exhaust headers for my d15b7 fit my d16y8 head?? Also porting polishing and milling the new head, what would be possible gains? Whats your take on it thanks.
- Sun Jan 31, 2010 11:24 pm
#172382
So d16y8 head and valve cover, do i use all d16y8 valve cover bolts ?? Can I reuse my d15b7 bolts> Also intake mani mouting hardware, can i reuse the d15b7 ones also<<<//
- Mon Feb 01, 2010 3:23 am
#172422
The covers bolts for the VTEC Style Valve Covers(D16z6, D15z1, D16y5,d16y7 and d16y8) all have different connection hardware, They bolts are pressed into rubber grommets which are pressed into the valve cover.
You can use a D15b7 intake manifold, However using a d16z6 or d16y8 intake manifold will allow in more air and flow better making more power.
What Gains will be had from Port and Polishing? Totally depends on how well they are done.
2017 Chevy BoltEV DD |2001 Honda CRV SE
