- Sun May 24, 2009 4:24 pm
#118508
gotta say it was quite a fun test drive.
3,778 cc 3.8 liters V 6 front engine with 96.0 mm bore, 87.0 mm stroke, 10.4 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder Lambda
95 lx sedan
88 rx7 base sold
93 del sol swapped b16a2-R.I.P
i'm addicted to 8200 rpms
"car inspection, what's that"
STDs cause you to fart lighting bolts.
88 rx7 base sold
