2016 Mustang GT350, Flat-Crank V-8, 500+ hp, 8000 RPM
Supposed 8000 RPM redline, MagneRide shocks, custom body parts.
For those that don't know the difference between a flat-plane crank and a traditional cross-plane crank:
And a bit about the MagneRide:
This isn't going to beat the 707HP Hellcat in a dragrace, but it looks like it's being built to run with exotics at a road course.
http://www.caranddriver.com/news/2016-f ... -info-news
The V-8 engine skips turbo- or supercharging in favor of a sky-high redline—there’s no official number yet, but we’ve heard 8000-plus rpm—and that fancy flat-plane crank, a trick favored by Ferrari. For those unfamiliar, a flat crankshaft design involves attaching the crank pins at 180-degree intervals rather than the usual 90; this allows for a firing order that bounces back and forth between the two cylinder banks, providing evenly spaced exhaust pulses.
MagneRide, Ford’s first-ever application of the continuously controlled magnetorheological damping system. This setup alters shock stiffness at each corner independently every 10 milliseconds based on the car’s yaw angle and suspension load.
