- Thu Mar 07, 2013 4:55 am
#327984
Long time no see. I have 2006 scion xb.and its also a 5 speed..the check engineIs on i scanned it and I says missfire cylinder 2 . Ive done some at home testing and injector is fine becuase you can hear it clicking and engine sounds some. What ok. I have also checked the coil For spark and while engine is running I lift the coil from spark plug and u can hear the clicking sound of the coil spark I have also taken the time to clean out throttle body. And I checked the. Spark plug which were change 4, 000 miles ago but only thing I found odd was thatthe number 2 spark plug gap was out of spec. It was at.049 when stock it needs to be at .032 factory setting . I made the qchange at it still felt and sounded the same. It has NGK GP PLATINUM SPARK PLUGS
I dont know whats wrong with the car . It has a rough idle while at stop lights and while I sits parked , its got this putt putt sound its not to noticable but I know it wasnt there. When u drive it it feels fine Smooth between shifts and RPMS. The bad part is im getting Bad gas milage. Let me know what you guys think .
Sorry about the grammer guys.
