A place for all vehicles that aren't 92-95 (96-97 Del Sol) Honda Civics
By eg6 Driver
#283016 i have this automatic honda accord that i dont know what is wrong with it. i took it to diagnose and they said the tranny need to be replace so i replace it with another tranny to save money w/o paying for someone to replace it. accord dont work yet after it. the shift lock solenoid still lock up. when i check for codes, the ecu light stays on. i heard that if the ecu light stay on it might mean that the ecu might not be working. so im thinking of gettign another ecu just to see if thats it. if not i want to sell it or trade for a civic 4 door or ef sedan.
By asianrob
#283018 its hard to decipher what your asking for.
what i would do since most auto accords have this problem is check the trans solenoids which usually goes out first.
i believe if its bad ecu it is code 0 or 11?
is it throwing anyother codes?
make sure everything is plugged in correctly
make sure your fluid is up to par.
By eg6 Driver
#283023
asianrob wrote:its hard to decipher what your asking for.
before, accord has been shifting at high rpm after replacing another tranny still same thing.
i cant tell if its throwing any code when i check for codes, the cel just stay on, not sure if thats 0 or 11. all sensor i made sure none was loose.
im going to drain the tranny fluid and put in honda fluid.
i replace other parts that i think it was not worth replacing but i did it just to make sure. my last guess is it might be the ecu or something electrical.
#283037 i work on honda shift and lock up solenoids alll day.. litery(sp)
i test em and hand em out to builders(i work at a honda auto trans reman shop)
the odds of the soleniods goin bad is slim...
(i know from testing them all day)
what kinda transmission did u replace it with
i mean like what year and where did it get replaced
By eg6 Driver
#283039
94_jdm_ferio wrote:i work on honda shift and lock up solenoids alll day.. litery(sp)
i bought it from a wrecking yard. the seller said it was for 1996 accord so i bought it. the install me and other family member did it ourselves it wasnt our first time.
By Apexracing
#283047 Replace the transmission control module
By eg6 Driver
#283051
Apexracing wrote:Replace the transmission control module
i would but the 1996/1997 4 cylinder tcm form into the ecu.
By Apexracing
#283053 Got ya sorry ive only owned a cb7 gen accord. I would try a ecu from a junk yard and try that
By eg6 Driver
#283054
Apexracing wrote:Got ya sorry ive only owned a cb7 gen accord. I would try a ecu from a junk yard and try that
just came back from the junk yard. there was one but it was manuel the others are already gone. thanks tho
By eg6 Driver
#283055
how would i test the shift lock solenoid?
By Apexracing
#283056 Is it worth while to do a manual swap?
By eg6 Driver
#283156
Apexracing wrote:Is it worth while to do a manual swap?
lol but no. dont want to deal with the accord again.
By eg6 Driver
#283272 i bid on a ecu on ebay and i won but im afraid the dude might not send it to me bcuz the starting bid was $20.00 and i just bid $20.50 lol
