- Thu Sep 27, 2012 5:57 pm
#316683
Please read the ENTIRE POST before contacting me, thank you.
All Parts, gaskets, and seals listed are BRAND NEW OEM HONDA. This literally is a brand new bottom end.
BLOCK
B18b Block Honed & Resurfaced
Micro polished Crank
Shot peened rods resized/honed for ARP rod bolts
ARP Headstuds
Clevite Main/Rod bearings
81mm ITR Pistons/Rings
ITR Oil Pump
ITR Water Pump
New thermostat
New timing belt tensioner
New rear main seal, oil pan gasket, waterpipe o-rings, and every other gasket/seal
Blasted/painted oil pan
This complete bottom end is all ready for your vtec head. It was completely blueprinted prior to assembly, NO CORNERS WERE CUT. If you're looking too build B series you won't find a better bottom end than this. As I said, absolutely everything is brand new from Honda. I do have receipts.
I am asking $1850 but am willing to entertain offers, I just need to make some money back on my investment. This block has just over $3000 into it. I am located in Racine, WI. Serious buyers can contact me via call/text at 262.902.9750 or email me at nathanfolks@gmail.com
BLOCK
ARP Headstuds
ITR Oil Pump
ITR Water Pump
New thermostat
Built not bought.
