- Mon Feb 06, 2012 1:54 am
#293453
Looking to sell my Ls swap, it's currently torn apart, I took the head off to send it to the shop, I still have everything in labeled bags, block is still together besides oil pan and pump, oil pan is tapped, only thing you need are axles ECU and harness, has stock mounts, altnator, starter, belts, all sensors besides iacv, my buddy who I bough it from said he text drove the car and there's no grinding in trans, but could use a valve adjustment, pistons do. Look fine, bearings are tight, has dizzy and hydro trans, I still have the clutch to
lemme know, call/TEXT text is better cause of work if you wanna call after 6 is best
names Dwayne located in akron area
price is 650 obo
price is 650 obo
"Only you, Can prevent your car from being blown away by a mini-van"
