- Tue Jan 01, 2013 4:19 pm
#323074
Due to a ton of work at my office, i haven't been able to do some work on the civic. On the 23rd an 24th of december, I continued with the wire-tuck on the driverside. Also tucked the wires to the BMC and roughly put the conversion harness in place.
It must have been a X-mas miracle. On the 27th of december, I had done something to the car or the motor every day for the last four days. Yesterday i stripped down the K20, so i can clean it and get it ready for some paint. Just need to clean off the really dirty pieces and maybe spray the first layers of paint this weekend.
On the 29th, i took some time to work on our daily. When that was done, i went out and bought a few wired brushes for the drill and cleaned up the K some more.
On the 30th i did a few little things, like degrease the K and replace the trans to bellhousing bolts with polished ones.
Today i fired up the heat in the garage, did the last bit of degreasing and taped up everything that shouldn't be painted on the K. Then i shot about 3 coates of dark grey heat resistant paint.
Just need to paint and mount al the loose engine components, change the clutch and mount the trans.
