- Fri Apr 13, 2012 9:57 pm
#301760
I really miss my purple ej. Probably my favorite build on here
- Sat Apr 14, 2012 12:38 am
#301772
according to the guy who makes/sells the cams... it'll make more than what im hoping for [230 whp]
EJ1_MK wrote:This is going to be sick nasty motor??
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Sat Apr 14, 2012 3:15 am
#301781
Sick build so far i will be keeping up with updates on this one thread. Good luck with the rest of the build.
- Sat Apr 14, 2012 6:07 am
#301796
Sweet, that will be one crazy lumpy with the ITB's and all. can't wait, but at your pace this time.
bks84 wrote:EJ1_MK wrote:This is going to be sick nasty motor??
- Sat Apr 14, 2012 6:27 pm
#301866
Ya, I'm getting excited.
Once the pistons show up, I can run the block and pistons to the machine shop and get that squared away. Just playing the waiting game.
- Wed Apr 18, 2012 5:46 pm
#302235
Valves showed up yesterday! Pistons showed up today!
I'll be running the block, crank, rods and pistons down to the machine shop to get everything cleaned up and the block bored/honed. I'll ship the had out tomorrow.
Machine shop said the block will be done Monday, so I'll probably pick it up Tuesday. I was hoping to have the shortblock assembled this weekend, but oh well.
Pictures.
Supertech 85mm 12.5:1 (+6.5cc) pistons
Golden Eagle cam gears, Decided to get these since the SRR's were sooo hard to read when degreeing. My blind friend should appreciate it. LOL
Pictures.
- Thu Apr 19, 2012 1:11 am
#302270
with 85mm dont you have to run sleeves or do the b20 run bigger bore??
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
91 s10 (sold)
- Thu Apr 19, 2012 2:09 am
#302273
blk92hb wrote:with 85mm dont you have to run sleeves or do the b20 run bigger bore??it'll be fine @ 85mm on stock sleeves. Did plenty of research before I made the decision. There's a lot of good info on hondatech believe it or not.
- Fri Apr 20, 2012 10:21 pm
#302452
decided to use a helicoil to fix my stripped slave mounted holes. worked well!
- Sun Apr 29, 2012 1:04 am
#303237
56lb ft mains
23lb ft rod bolts
Used suprtechs method for ring gap specs..
3.346" (85mm) x .0045 for top ring
Top ring gap X 1.25 for second ring
.015 top ring
.018 second ring
.015 oil rings
Everything is butttond up. gotta work early all this week so idk when ill ship this head off exactly.
my cams should be here next week... hopefully.
56lb ft mains
23lb ft rod bolts
.015 top ring
.018 second ring
.015 oil rings
