Yeah I have a 4dr, no you can't have a ride.
- Mon Nov 19, 2012 4:32 am
#320277
Good stuff! You dont have your factory corner lights still do you?
- Fri Nov 23, 2012 6:45 pm
#320723
the plug your missing can be found in most yards, its the same plug used on the ac compressors. much better than tapping stuff together.
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Tue Dec 04, 2012 12:37 am
#321475
New actuator and new strut braces arrived (top and bottom, front and rear).
Just waiting on results of MOT, then, if all goes well, its boost time.
Built not Bought
building a daily 300-350hp d16z6.
I'm so JDM.... I named my cat MUGEN lol
- Tue Dec 18, 2012 8:47 pm
#322447
Update.
Started the turbo build today, but only managed to bolt up ic, fit oil plate with sensors and fit DSM injectors.
Done my dials a few days ago
Also wired crx resister box into d16z6 engine loom
Built not Bought
- Wed Dec 19, 2012 6:15 pm
#322504
Update.
Bolting things on and had to slightly cut the fan cover a bit to clear actuator, sorted the wiring and injectors out aswell as slightly modding i/c piping to avoid cutting passenger side front tow eye/bracket.
Just hit a problem with the oil sump, almost all the 10mm nuts/bolts are coroded bad, so that couldnt be done today, start on that tomorrow.
And been cutting the inside of front bumper so it sits abit better, hopefully more progress tomorrow and completion.
Built not Bought
- Thu Dec 20, 2012 4:15 am
#322531
comin along nicely
- Thu Dec 20, 2012 4:58 am
#322535
Man I'm seriously thinking of going turbo with my d series like I figure hardened enternals with a rebuilt head I'll probably be happy
- Thu Dec 20, 2012 6:15 pm
#322562
Thanks
Ive got a spare z6 in the shed to rebuild, might forge it and keep car D-series.
Update.
Oilpan is off and tapped one fitted. Was a pain in the ass, as the bolts/nuts were perished. Angle grinded a bolt head off and split a nut in two just to remove it, also one thread snapped. So new pan will have two fasternings missing.
Just the exhaust left to do tomorrow as i got soaked with it raining, so with the rain i didnt get to take any pics, take the bumper off again to cut it more, or do the full exhaust.
Plus gunna grind a wedge out of the block where compressor is, as ive been advised to do so to accomodate for any vibrations, so the turbos need taken off.
Really hope this starts up and runs, or it'll have to be put back to NA before monday.
Update.
Built not Bought
- Fri Dec 21, 2012 11:53 pm
#322635
Got boost! But taking it carefully.
Ecu is mapped to 7psi
Actuator has a 7psi spring
Boost controller set at 5psi
Just driving it in vaccum, but the temptation is there.
Exhaust is 3-4inches too short so that needs an extention to fit properly, also a irratic idle problem has occured.
Soz bout the shaking, but nerves and cold got the best of me.
http://i729.photobucket.com/albums/ww29 ... A8422C.mp4
Built not Bought
- Sat Dec 22, 2012 12:40 am
#322637
Nice Progress!!!
Makes me wanna go turbo
94' civic si
JDM B16A w/AC
JDM B16A w/AC
