Punksz6 wrote:Looking Good!
Thank you
Coupe Crew #17
Fada Blayne wrote:Wats next?
jayEGR wrote:looks better with the white rims
greggarcia wrote:hey i really like the color of your car
Chambers wrote:Wow, you have done well. Your car look good.
As for the HVAC, from the HCRM it says to remove the lower panel (the one with the ash tray and cig lighter, the panel has a few screws and one plug). Then remove the radio, then remove the three self tapping screws on the HVAC control unit (they are on the bottom). There are two plugs on the back of it, also a cable attached to the heater core that needs to be undone (on the heater core side) to remove the control unit as a whole from the chassis. Its just like a throttle cable, simple metal cable with a ball at the end. Finally you have to pry the little tabs of the front cover on the control panel to get it off, that will reveal the buttons and I'm assuming the back lights. Now the lights, I'm not sure what size they are, I haven't pull this stuff apart to replace mine yet. I need to replace all the back lights for the unit, switching air control at night was like shooting blind folded until I got used to the controls, haha.
Keep up the good work, good luck!
