- Sun Oct 03, 2010 8:57 pm
#216646
Haha thanks. Me too. Too bad it hardly ever gets out of my garage. Already got new pistons in and block is getting bored this week. Should have it all back together this weekend. Wish me luck.
- Wed Oct 06, 2010 2:34 pm
#217127
good luck man! hopefully you get this shit under control...sucks so much ass, who's tuning?
- Thu Oct 07, 2010 7:28 am
#217287
Yeah I hope so too, I want to go out one last time this year lol. And a local shop by me. Big 3 Racing
- Sat Nov 13, 2010 10:05 pm
#222811
Hey with the .5 oversized vavled did you have any piston to valve clerances issues? Cuz i am thinking of getting those for my d series build but not sure.
- Tue Dec 28, 2010 8:23 pm
#230210
No problems with p2v clearance with the oversized valves, but the vitaras also sit below deck. Shouldn't have a problem.
Haven't been on here in a while again but some more bad news. Got my freshly built block in good compression ready to hit they dyno, and spun number 4 rod bearing again. Got sick of the Y8 and their shitty oiling systems.
But good things to come.
Picked up a D16Z6 block, supertech 10.5:1 comp pistons, eagle rods, brand new crank, new oil pump that is being built now.
No more crower cam upgraded to the bisimoto level 3.6.
Brand new garrett 60-1
New turbonetics evolution wastegate
2.5" intercooler piping
Tial 50mm bov
And much more goodies.
Shooting high next year. Wish me luck.
Tial 50mm bov
- Wed Dec 29, 2010 3:19 pm
#230346
good luck sir! that's for sure a good list you have going there... I'm always really happy i had a z6 block with the double chamfered oiling ports vs. the y8.. however, did you shim/port the oil pump? you should port the new z6 pump especially if your going to be spinning to 8k+ RPM?
anyway, good work!!
anyway, good work!!
- Wed Dec 29, 2010 5:52 pm
#230370
Yeah I ported it because I had spun a bearing before about a year ago. And yeah I have nothing but problems with the y8 hopefully z6 will bring me some luck. Also having a shop put it together this time, I just want to make sure its perfect. Was debating on porting the new pump or not, a lot of guys say don't have to with the z6, but I might just to be on the safe side, considering I should be hitting around 9k rpm.
- Thu Dec 30, 2010 10:03 pm
#230598
damn 280whp @22psi. what's the flow rate on the turbo?.
Team XXX Racing/WGHonda
- Thu Dec 30, 2010 10:05 pm
#230599
Awesomeness
BoostedD16 wrote:No problems with p2v clearance with the oversized valves, but the vitaras also sit below deck. Shouldn't have a problem.
Tial 50mm bov
Awesomeness
- Fri Dec 31, 2010 12:46 am
#230610
Ebay 50 trim so who knows what it was... and that was with a shitty wastegate that was leaking. I will be happy with around 350 on the new set up.
EG6b20R wrote:damn 280whp @22psi. what's the flow rate on the turbo?.
- Thu Jan 06, 2011 3:27 pm
#231732
thats what i did, brought a brand new pump, tore it apart and ported it.. it's nice to have some re-assurance when your spinning that high, you need oil to be delivered to the bottom end and everything else. i would do it even on a z6 just for peace of mind and maybe you can quite spinning bearings
good luck dude! keep us posted
BoostedD16 wrote:Yeah I ported it because I had spun a bearing before about a year ago. And yeah I have nothing but problems with the y8 hopefully z6 will bring me some luck. Also having a shop put it together this time, I just want to make sure its perfect. Was debating on porting the new pump or not, a lot of guys say don't have to with the z6, but I might just to be on the safe side, considering I should be hitting around 9k rpm.
- Fri Jan 07, 2011 7:58 am
#231883
good luck dude! keep us posted[/quote]
Yeah definitely don't want anymore problems with this thing.
- Thu Jan 13, 2011 4:10 am
#232954
Sooo was doing some reading last night. Got on the subject of flex pipes. Did some searching, one guys eclipse said was just built and only making 9-10 psi. No vacuum leaks, exhaust leaks, boost control worked, was tuned the whole 9 yards right? Sounds like my problem, Caught my attention!
Went to look at my downpipe where flex pipe is. Bam, think after months of searching and replacing internals of motors I found my problem.
