- Wed Dec 21, 2011 4:41 am
#286326
When looking at the valve cover, there is no line on the right side, only the left. So yes the left (black circled) would go to the catch can.
nevermind that oil line in the previous pic... there is normally an OEM oil pressure sensor there. I recommend using an oil sandwich plate adaptor between the oil filter and the block to give you additional ports which you can use one for your oil feed line and use another one for the sensor to control your aftermarket oil pressure gauge (recommended for turbo setups)
