- Thu Jul 03, 2008 3:23 pm
#60626
http://causeforalarm.thecarthing.com/ve ... index.html
The 3 Stage VTEC motor has both VTEC-E and VTEC in one motor. That's how I'm able to get VX mpg and Si power all at once. The motor looks just like a D16Y8 but has two VTEC solenoids as you can see in the top left of this pic:
VTEC-E is a mechanism that switches from 12 to 16 intake valves. This gives you better low to mid RPM than the VTEC motors. It also allows you to run very lean mixtures at cruising.
SOHC VTEC as you know changes the timing, lift, and duration of the intake valves for high RPM power and allows a non-VTEC cam profile that is optimized for low to mid RPM power, mileage, and emissions.
