- Mon Apr 27, 2015 11:57 pm
#353453
Thanks, the integra rear seats are a mix to make them fit properly, you use the seat backs as they are from the integra then you remove the material from the integra base and wrap it over the standard civic base else you end up with a large gap between the base and the seat back, hope this helps
- Sun May 24, 2015 10:38 pm
#353891
another update, managed to swap the dizzys for the correct one, sort out the missing pipes / and the extra plugs so everything is connected as it should be, have given up on the integra airbox for now as cant get it fit comfortably so need another solution eventually but close to putting the fluids in and trying to start her up now, also fitted a gen 1 spoon 4-2-1 manifold
managed to finally pick up my coilovers, went for meister zeta r which should be going on next weekend along with the roll bars, polybushed arms etc
and decided to trim the rear inserts inside to match the front door cards not seen many people do it thought would break up the black a bit
